1/25/2011 7:12 AM | |
Joined: 6/17/2010 Last visit: 4/26/2022 Posts: 30 Rating:
Dear friends i am new to wincc flexible and 400h systems how to make communication betwwen two ? if i simulate using plcsim via mpi its working in the case via ethernet i am not geeting any ubdates i have attached my config Attachmentconfig.pdf (36 Downloads) |
1/25/2011 9:29 AM | |
Joined: 4/24/2006 Last visit: 2/2/2023 Posts: 8586 Rating:
Hello, Perhaps the following link might help: how do you connect a panel to a SIMATIC H station? how can you have any number of automation systems addressed one after the other by the "Change Connection" function with WinCC flexible PC Runtime or a Panel? Best regards, Wizard |
1/25/2011 11:05 AM | |
Hello, Please have a look at this link: how do you configure a connection between WinCC flexible Runtime (PC or Panel) and a SIMATIC S7-300 / S7-400 via Industrial Ethernet? Best regards, Wizard |
1/25/2011 1:33 PM | |
Hi, What is the version of PLCSim, you are using? Best regards, Wizard |
2/1/2011 9:12 AM | |
my plcsim version V5.4+SP3 |
