4/1/2010 2:44 PM | |
Joined: 12/9/2009 Last visit: 4/18/2024 Posts: 156 Rating: (11) |
Hello, did you already contact Intouch Wonderware??? What did they say??? Best Regards Little Holmes |
4/1/2010 10:26 PM | |
Joined: 4/19/2008 Last visit: 11/21/2024 Posts: 1525 Rating: (159) |
Hi KevC, In the Wonderware you can achive this by using the Scrip for the Node for that write the logic in PLC Which CPU is Master you will Find the Block Here & switch the Node in the woderware side by using the Script. But you have to Spend more time on wonderware side to work. |
Ammy |
