4/5/2011 6:28 PM | |
Posts: 15 Rating:
Hello, Please accept my deep appreciation to your help and fast response. Now kindly note that Idid what you have just told me and for some reason I can’t get an active connection between the PLC and the PC (other station1), whatever I do I never get active/established connection in Netpro down side!!! Honestly I don’t know why? But I used the same configuration (IP address)with another device (Moxa MGate 3080) and I obtained a good connection which really makes me very confused and now I can’t understand why it’s not working with my PC. I’ve attached the program with hw configuration and Netpro configuration, and I hope it would clear the problem for you. Also I need to tell you that I’m using a straight cable between the PLC’s CP and PC, and I’m using a regular Ethernet card in the PC. Thanks again and best regards. Attachmentproject.zip (293 Downloads) |
