7/6/2017 4:34 AM | |
Posts: 10 Rating:
Hello koenb! I'm facing a problem like you before, Can you tell me how to communication s7-1200 and Diris A40( read address 505xx). ------------------------------------------------------------------------------------------ |
Last edited by: Jchip at: 7/6/2017 4:35:12 AMLast edited by: Jen_Moderator at: 7/6/2017 2:54:27 PMNew subject after splitting |
7/8/2017 4:41 PM | |
Joined: 2/22/2016 Last visit: 3/19/2025 Posts: 142 Rating:
HI Jchip. I have a ready plc-program for you, see attachment. If you encounter problems I can try to help you. Regards, Ola AttachmentSocomec Diris.zip (645 Downloads) |
2 thankful Users |
7/9/2017 8:44 AM | |
Posts: 10 Rating:
Thanks Olo84 Did you have communication S7-1200 and TZN series (Autonics) ? AttachmentTZ-TZN_communication control.pdf (557 Downloads) |
8/4/2017 8:32 AM | |
Hi Jchip. I am sorry, there is was a bug in the modbus library. I have updated attachment with the bug fix. Good that you where able to dig out the error code your self, if you uncheck "Optimized blocks access" for mb_master_ctrl it will most likely also solve the problem, but no way that you could know that. I will anyway recommend the new version because that one runs a bit faster. Please tell if you should run in to some other problem. Kind Regards AttachmentSocomec Diris.zip (454 Downloads) |
