5/17/2010 1:42 PM | |
Joined: 9/23/2005 Last visit: 2/3/2023 Posts: 4178 Rating:
Hi you can use USS protocol with a MM420. the internet examples doesn't use MM420, but it should works. You could be adapted to use it: http://support.automation.siemens.com/BR/view/pt/40157517 http://support.automation.siemens.com/BR/view/pt/40616058 http://support.automation.siemens.com/WW/view/en/37604154 other post talk about some adaptations: https://www.automation.siemens.com/BR/tf/WW/en/Posts/33608 |
6/17/2010 2:40 PM | |
Posts: 27 Rating:
hello, iposted earlier some infos about this subject check this link /tf/WW/en/Posts/43531#top Regards Aminadra |
10/2/2014 10:32 AM | |
Posts: 10 Rating:
hello.
i'm a new beginer so i don't know much about comunication between s7-1200 and mm420 drive by using USS protocol. Can you send me examples for this problem ? thank you ! sorry , my English is not good. |
10/2/2014 2:35 PM | |
Joined: 7/7/2010 Last visit: 2/6/2023 Posts: 13081 Rating:
Like you, I have not clicked any of the links posted above to solve the problem you are posting about. I will say that there are FAQs on how to communicate with s7-1200/MM4x0 drives. Just use that search box up there ^^^^^^---------^^^^^^ and think about how Siemens words their FAQs and see if you can get your answer as the first returned result. I think you might get the top 5 without much trouble at all, but let's see if you can get #1 ! |
science guy |
10/15/2014 9:08 AM | |
Joined: 9/3/2014 Last visit: 3/13/2019 Posts: 4837 Rating:
