12/2/2013 2:47 PM | |
Posts: 1368 Rating:
Hello andreas_CHE, thisconstellation could work: you can use the PROFINET interface of the PLC to communicate with your devices.The CP1543-1 you use to communicate to the S7-300 PLC via Ethernet and using the open communication blocks. Look here for the open communication blocks: http://support.automation.siemens.com/WW/view/de/78028908/0/en (chapter 21.7.5) Greetings, Pittiplatsch |
