6/11/2015 6:52 AM | |
Posts: 25 Rating:
Hi, With reference to Modbus_Master of RS485 that I would like to know about it in order to ensure appropriate setting such as programming and setting in the Step 7Manager tool before begin commissioning test. Please, look at the below what I do and then could you give me some advise tip on how to define properly without some of troubles if there are some problems. Also, see attached program files.
Start Bit : 1 / Data Bit : 8 / Stop Bit : 1 Speed : 9600pbs Parity : even
DB42.DBB0 : 1 (Slave Address) DB42.DBB1 : 4 or 16 (Function Code) DB42.DBW2 : 0 DB42.DBW4 : 20 DB42.DBW5 : DATA1(Whole Length : 20 WORD)
Thanks you very much for your cooperation.
JongMin, Hyeon(Jake)
AttachmentDg_syste.zip (403 Downloads) |
10/28/2015 2:53 PM | |
Joined: 9/3/2014 Last visit: 3/13/2019 Posts: 4766 Rating:
New question published by www.dientuvietnam.net/forums/forum is split to a separate thread with the subject How to test Modbus Master Cp341 in S7-Cpu135 with Slave PG. Best regards |
