5/13/2023 3:01 PM | |
Joined: 1/7/2018 Last visit: 12/6/2024 Posts: 1 Rating: (0) |
Hi Sr.Denilson can you help me i had install TIA V18 Update 1, and i had also TIA V17 update 6 When i Try to load my project into simulation in unified V18 update 1 next error appers Communication error 8020AB001992FFF4 I have no idea about why this happens in V18.0 i had install also the unified runtime PC as recommend in other post before i did the upgrade to v18.1 for my instance of TIA V17 update 6 all works perfect in simulation project im able to access webserver and simulate my project ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 05/15/2023 09:45:20New subject after splitting |
5/16/2023 12:15 PM | |
Joined: 5/6/2022 Last visit: 1/10/2025 Posts: 533 Rating: (109) |
Hi Luis HC, I have been reviewing information about the error code but I have not been able to find anything other than the following post where this error is mentioned -> HMI Download canceled due to a transfer error: 8020AB001A06FFF4 I know that it is not exactly the same situation, but any solution that is discussed may help...
