12/13/2009 10:24 AM | |
Posts: 382 Rating: (47) |
Hello, Well, I haven't encounter before. Maybe you got to look into the baud rate and the distance of communication between your CPU and TP and also your wiring connection. Try these links and maybe they are helpful to you. 1] Acceptable line length in PROFIBUS-DP networks 2] How many meter mpi communication? Hope this helps! with regards, how come AttachmentProfibus Connector 90deg Double 9pin Screw Type.pdf (101 Downloads) |
