2/16/2011 3:47 PM | |
Posts: 5 Rating:
Check in the PG/PC interface, what is your baud rate? If the CPU baud rate will not match your PGs baud rate, you will not be able to go online. Capriconian
2/16/2011 3:55 PM | |
Joined: 3/21/2006 Last visit: 3/17/2025 Posts: 10239 Rating:
Hello, As mentioned in previous post by Capriconian, make a MRES of CPU and try again with PG/PC MPI interface with default settings. Best regards, Hristo Mihalev |
2/17/2011 5:55 AM | |
Posts: 8 Rating:
I have tried every thing, also bring CPU to default setting but no communication established. How todiagnose MPI port is fauty |
2/17/2011 9:38 AM | |
Posts: 378 Rating:
Hello Danish, maybe the following thead helps you Program Downloading Probem. Best regards Bilao |
2/17/2011 10:25 AM | |
Posts: 28 Rating:
Hi Danish Try changing changing the highest station address to 126. Had a similar problem and this worked for me. Warm Regards |
