1/28/2009 12:06 PM | |
Posts: 5822 Rating: (412)
Hello adam_son, well... this is not really easy to answer but I guess there are two points to check for this problem. |
1/28/2009 3:28 PM | |
Posts: 4 Rating: (0) |
Thank you for reply. On Simatic Microbox PC is installed SIMATICNET PC/Software Edition 2006. But I don't understand what relation it has with VS2008? The VB application that is made is running on remote PC as OPC client. About DCOM settings: I found out in some SIMATIC NET specification that if computers works in a workgroup there can notbe made any authentication. So it means that in DCOM settings authenticantion level should be set to NONE on both sides. Is it true? |
2/5/2009 1:41 AM | |
Joined: 4/20/2007 Last visit: 1/3/2025 Posts: 29 Rating: (2) |
Dear all: |
