10/24/2024 9:24 AM | |
Hello HİM61 If you have WinCC Professional or Unified you can use a Tag from the communication channel and check the quality code to see if you have a connection for Comfort/Advanced you can try to use this: https://support.industry.siemens.com/cs/de/en/view/109481628 Bye Murof |
