6/15/2022 10:51 AM | |
Joined: 11/30/2015 Last visit: 1/25/2023 Posts: 13 Rating:
Hello , Do you know if it is possible to communicate Wincc Unified PC with a PLC S7 200 + CP 243? Thank you.
6/15/2022 11:32 AM | |
Joined: 2/17/2020 Last visit: 1/27/2023 Posts: 701 Rating:
Hi ahita, I am afraid that the communication of a Unified system with S7-200 is not released: SIMATIC HMI WinCC Unified Engineering V17 - Supported PLCs That is, you can try and work or not, but it could not be guaranteed. Perhaps OPC communication is the best option, but again, it may not work. |
If this post helped you in any way, please rate it positively. |
6/15/2022 12:40 PM | |
Joined: 9/27/2006 Last visit: 1/29/2023 Posts: 11946 Rating:
Hello ahita; Itafusna's answer is quite correct, in the sense that WinCC Unified is a recent addition to Siemens line of HMIs, whereas the S7-200 family has been discontinued for some years. Therefore the connection methods between a S7-200 CPU and a WinCC Unified station might not be updated in their respective documentation. Possibly this FAQ can provide some of the information you seek, it addresses communication options between a S7-200 and WinCC Classic (v 7.x), and discusses various OPC servers that could help you out if you choose to go that way: either PC Acces or Simatic Net. Make sure you take into account the version of Windows that supports you Microwin software for S7-200 programming, that might be a limiting factor in your selection of communicaton drivers.. https://support.industry.siemens.com/cs/ca/en/view/21915573 Hope this helps, |
6/17/2022 3:00 PM | |
Thanks for the reply. I will try the option with OPC. Best Regards.
