7/15/2009 7:24 AM | |
Joined: 3/21/2006 Last visit: 7/26/2024 Posts: 10228 Rating:
Hello, Standart way is to connect barcode to PLC and into computer just to read/write data. I don't know what kind of 314 CPU you have, but if your type is 314-2PtP you can directly connect this barcode device. Look at attachmen one exmple that I found here. If your type of CPU is different then take one CP341 serial communication processor which will help to connect barcode readers. About your idea to connect via USB and then to read/write with CPU, I think with "standart Siemens software" is not possible. Hope this will helps. Regards, Hristo Mihalev AttachmentBarcode.zip (635 Downloads) |
11/19/2010 8:35 PM | |
Posts: 4 Rating:
Look at this Tip: Hope this helps
