10/19/2015 5:55 PM | |
Joined: 5/12/2006 Last visit: 2/2/2023 Posts: 21218 Rating:
Hello, for this you need S7 Routing. Here you can check if you CP and CPU support S7 Routing: https://support.industry.siemens.com/cs/ww/en/view/584459 To use the S7 Routing your should assign a PG/PC to the project and connect it with the Network1 of the PLC. Regards Christoph |
