3/10/2008 2:29 PM | |
Posts: 279 Rating:
Yes, RSView32 does support OPC. OPC is probably used already with the SST Profibus card. |
3/14/2008 9:43 AM | |
Posts: 279 Rating:
You need Simatic Softnet Ethernet Lean. With this you setup an OPC connection that RSView32 can use. You can use just the normal ethernet NIC in the PC. |
1/12/2017 3:48 PM | |
Joined: 9/3/2014 Last visit: 3/13/2019 Posts: 4827 Rating:
New question published by Maicon Galiazzi is split to a separate thread with the subject Communication PLC S71200 with RSView32. Best regards |
