3/4/2008 9:03 AM | |
Joined: 10/19/2005 Last visit: 11/30/2020 Posts: 1611 Rating:
Hi, generally -> if you using info about for sample flexible, you will find it on the customer support sites from Siemens. -> http://support.automation.siemens.com If you want to save data, then you should using a CF or MMC Vard. You should not use for this the "internal flash", because the lifetime of the panel will be reduced. Info about audit -> http://support.automation.siemens.com/WW/view/en/24327008 or look into the online help from WinCC flexible. regards, |
