4/5/2017 3:13 PM | |
Joined: 4/26/2016 Last visit: 3/3/2021 Posts: 6 Rating:
I need a sort of solution with a related problem. Also i want to compare a VM value, but i want to compare it with value of a up down counter. If the VM value is higher then the counter value, then output 1 If the VM value is lower then the counter value, then output 2 Maybe someone can help me with this problem. Best regards. ------------------------------------------------------------------------------------------ |
Last edited by: Min_Moderator at: 4/5/2017 3:18:23 PMNew subject after splitting |
4/5/2017 3:35 PM | |
Joined: 12/18/2014 Last visit: 12/5/2023 Posts: 31546 Rating:
In attachment a possible solution.
AttachmentCompare_VM-value_and_Counter-value_0BA8.Standard.zip (142 Downloads) |
4/5/2017 4:13 PM | |
Hello Hanvanvliet, you're welcome. |
