8/13/2014 8:47 AM | |
Joined: 4/22/2010 Last visit: 2/15/2024 Posts: 5697 Rating: (711)
Hello, I guess you are using windows 7 (64), to get the help working you need to install winhlp32 A compare intruction checks the 2 inputs to be i.e equal , see attachment for more. A move copies (when enabled) a variable to another variable, L(oad) and T(transfer) in STL. Input and output variable must be of the same datatype (in lad or fbd). Regards, Marcjan AttachmentPrinting _SIMATIC FBD Compare Instructions.pdf (152 Downloads) |
Problem solved? |
