4/12/2022 1:17 PM | |
Joined: 5/12/2006 Last visit: 4/17/2025 Posts: 22620 Rating:
is compatible LTSB is the old name for LTSC AttachmentWinCC-RT-Professional-(TIA-Portal)_en_2021-08-31.pdf (342 Downloads) |
4/13/2022 10:50 AM | |
Hello Hmimed if you do not know if a SW is compatible to a windows os then you can have a look here: https://support.industry.siemens.com/cs/ww/en/view/64847781 More Information about the naming of the long term versions you can find here: https://docs.microsoft.com/en-us/windows/whats-new/ltsc/ ----- The Long-Term Servicing Channel was previously called the Long-Term Servicing Branch (LTSB). All references to LTSB are changed in this article to LTSC for consistency, even though the name of previous versions might still be displayed as LTSB. ----- Bye Murof |
