8/6/2007 10:27 AM | |
Posts: 1 Rating:
Hi, Is WinCC/Dat@Monitor compatible with PCS7 v6.1? Our local Siemens representative says it's not... Is this correct? Thanks, Jerry |
8/7/2007 11:54 AM | |
Posts: 1776 Rating:
Hi, Its correct, what Your local Siemensrepresentative says. The released Software You can find in the readme.wri Butthis meansthis Software is tested. But... You can tryDat@MonitorI think it should work probably. Best regards April |
8/16/2007 4:01 PM | |
Posts: 37 Rating:
Hello, Please be carful as depending on the version of PCS 7 you have you may need a differnt version of Dat@Monitor. PCS 7 V6.1 = Dat@Monitor V6.1 PCS 7 V6.1 SP1 = Dat@Monitor V6.1 Asia Best regards, |
