12/6/2010 1:47 PM | |
Joined: 6/29/2010 Last visit: 10/27/2022 Posts: 112 Rating:
Hi sunscreen, At Extended Instrutions, String+Char, you can use the CONCAT block. Regards. |
12/10/2010 2:37 PM | |
See attached for a quick approach to allowing 0 .. 10 SMS destination numbers. You may need to adjust to suit your specific application, but it should show you a solid approach than doesn't use the relatively unsafe practice of looping. I use looping fora specific application which I know - formyproject -it is the right answer. The attached approach seems more appropriate to your application and current understanding on S7-1200 basic. AttachmentSMS_Message_Handler.zip (171 Downloads) |
science guy |
