8/29/2010 4:50 AM | |
Joined: 10/7/2005 Last visit: 9/20/2024 Posts: 3021 Rating: (1054)
Hello rara export to memory card isonly available after you selected the (IM308C) DP Master Station that you want to export (bear in mind that you could have more than one DP Master in your COM PB project). Simply select (single click) your DP Master and the "export to memory card " icon should come "alive" (see also attached screendump). I hope this helps |
Cheers |
