8/21/2009 10:16 AM | |
Posts: 261 Rating:
Hi UMENCHO, Thanks for your reply. Can you guide us more? I downloaded the file but unable to proceed. With best regards ddg |
1/9/2010 10:30 AM | |
Joined: 1/2/2010 Last visit: 2/8/2023 Posts: 4 Rating:
Dear Hristo Mihalev; Thanks for immediate reply. I have shared screen shots in attachedjpg files about server settings. If you need further screen shots I can share. Thanks in advance. Yavuz Selim AYDIN Electronics Engineer AttachmentSMC_intouch_screenshots.zip (1300 Downloads) |
1/11/2010 8:14 AM | |
Joined: 3/21/2006 Last visit: 3/30/2025 Posts: 10239 Rating:
Hello Yavuz Selim, So, settings in SMC are OK. You created Device name: Project_PLC. Now this should be connected in Maker with access name. Look at attachment. Hope this will helps. Best regards, Hristo Mihalev Attachmentexample.zip (1106 Downloads) |
1/12/2010 11:29 AM | |
HelloHristo Mihalev; I am sorry for occupying your valuable time. I had already done the parameter setting which you mentioned in attached pictures but it did not work. In my opinion problem is about connection between DASSIDirect and NetToPLCSim because tags are active but they are not listed or counted in"read request" section in NetToPLCSim. I tried lots of things but not helped. I attached screen shots showing the situtation. I need your further help. Thanks in advance. Yavuz Selim AYDIN Electronics Engineer AttachmentSMC_intouch_screenshots2.zip (1013 Downloads) |
