8/24/2010 10:58 PM | |
Posts: 71 Rating: (0) |
HI, Attachment840D sl HW.zip (544 Downloads) |
8/25/2010 10:36 AM | |
Joined: 1/19/2008 Last visit: 10/2/2024 Posts: 992 Rating: (64) |
Hi, Same problem only the profinet version on the cd I'll attach it below. Hopefully you can save it. If not drop me your email in a private message Note I have changed the file extension to zip to allow the upload on the Siemens system. Change the file extension to GSD it is NOT a zip file. Pee AttachmentSIEM80A2.zip (658 Downloads) |
8/25/2010 4:15 PM | |
Thank you Pee Icouldnt open the file. I sent you a private massage contain my Email so you can Emailed me the file. Regards Tarik |
8/27/2010 6:06 AM | |
Posts: 2964 Rating: (484) |
Hello.... Could check the addressing on the PP module? The addresses are set using the DIL switch S1 on the PP module..... I am attaching you the document of the same for the referernce..... Check it out.... Regards, Ekalavya Attachmentpp module.pdf (537 Downloads) |
