2/24/2006 3:45 PM | |
Posts: 3149 Rating:
Hi Vidarv, I think this FAQ is ok, but not enough. You´ve now ensured, thata basic network is available. But your Windows-users still need the correct userright for e.g. accessing data/files on each of your computers. => e.g. open microsoft explorer >e.g. "Harddisk C"> properties > shares => are your Client users allowed to access the harddisk of your server? Did you install/activate any firewall? Normally you do the engineering on your engineering station. From there you are downloading your project to Server and Client. There are different ways for creating tags in WinCC more or less automaticly: - Use AS-OS-Engineering: http://support.automation.siemens.com/WW/view/en/22062395 http://support.automation.siemens.com/WW/view/en/14054155 http://support.automation.siemens.com/WW/view/en/775166 For creating tags in WinCC tag management you can use the Variable Import/Export Tool (WinCC online help > smart tools) or the "configuration tool" http://support.automation.siemens.com/WW/view/en/13681075 Enjoy the weekend :-) Nemo |
2/24/2006 5:28 PM | |
Posts: 66 Rating:
Hi Nemo! Thanks for your efforts this far! => e.g. open microsoft explorer >e.g. "Harddisk C"> properties > shares => are your Client users allowed to access the harddisk of your server? So I should share the complete harddrive on the server ? Not only the folder I download my application to, which is what I'm doing now. My windows firewall is disabled, no othe firewall installed. I wish there were a manual giving details for client-server integrated in S7, I belive this is a common way of doing multi-user projects ? - Use AS-OS-Engineering: http://support.automation.siemens.com/WW/view/en/22062395 http://support.automation.siemens.com/WW/view/en/14054155 http://support.automation.siemens.com/WW/view/en/775166 This requires PCS7 installed or am I wrong? Enjoy the weekend Nemo ! Vidar |
Last edited by: vidarv at: 2/24/2006 5:44 PMLast edited by: vidarv at: 2/24/2006 5:29 PM |
2/27/2006 3:05 PM | |
Posts: 66 Rating:
Hello again! So I guess I'm doing better? At least I think I am!
1. I did the S7 manager set up as described in : http://support.automation.siemens.com/WW/view/en/17581871 2. Skipped the set-up in the Station Configuration editor and SimaticNet, I am just using the Ethernet in my workgroup. Do I need to do any set-up of SimaticNet for the Engineering station-server-client communication? 3. I included the Engineering station as a client in the Computer list in my WinCC project, this I think was what really did the C-scripting possible ! (?)
