3/13/2009 1:15 PM | |
Posts: 18 Rating:
hi Ins will you tell me for which purpose we can use CP443-1 1EX11 Regards Vinot |
3/13/2009 4:09 PM | |||
Joined: 9/27/2006 Last visit: 3/18/2025 Posts: 12344 Rating:
Hello vinot; As pointed out earlier by INS, [Quote] You can connect SCADA and/or HMI Panels over ethernet. [/Quote] Look at the Tag management editor, under S7 Protocol suite, you will find the "Industrial Ethernmet" driver. You can create tages to your PLC on each of your SCADA stations there, using a standard switch to connect the nodes. You will probably need a IE Softnet-S7 driver to use the computer's NIC with Industrial Ethernet; look at the following:
Look at the Online Help for Industrial Ethernet connections information, or look at the WinCC Communications manual (on your WinCC installation CD). Hope this helps, Daniel Chartier |
