2/21/2014 3:47 PM | |
Posts: 1 Rating:
Hello, I want to use Mobile Panle 277f iwlan (RFID) in plant with ET200S CPU in TIA portal. I configured it in agreement with TIA portal help and mobile panel 277f function manual as you can see on screenshots. The problem is that application on HMI can't start because of no PROFIsave connection and configuration error on HMI. I think that I conifigured everithing correctly so can you please help me to find what is wrong or give me advice or manual for configuration in TIA portal? Thank for your answer. Problem is solved. The problem was with default F-monitoring time (must be at least 500ms) and in project must be used effective range with checksum 918. Attachment277f iwlan hmi.zip (255 Downloads) |
Last edited by: Zabka at: 3/3/2014 12:17 AMAdded solution. Last edited by: Zabka at: 2/21/2014 3:53 PM |
