4/14/2015 8:22 PM | |
Posts: 93 Rating:
Hi all, I have two s7-400 cpu 1) CPU412-2DP 2)CPU416-2DP I need to data interchange between two CPU.now we are using put&get function. i need to data transfer in global data communication method also. Any body tell me how to establish the configuration in NET PRO. what are the procedure to develope the program in netpro.Now both cpu hardware wiring done. need to be done the netpro also.pls guide me. Question: I need to both S7 station in a single net pro programming. i read in help menu to establish configuration, the reduced subnet length and trag the mouse to MPI connection not able to connect. so tell me how do edit it. here i attached my net pro program for both CPU Advance Thanks&Regards, Suryamuni. Attachmentconfigure global data.pptx (707 Downloads) |
4/15/2015 4:12 AM | |
Joined: 10/21/2013 Last visit: 3/15/2025 Posts: 421 Rating:
Hi surya, please find this post https://support.industry.siemens.com/tf/ww/en/posts/manual-for-mpi-communication-between-two-siemens-s7-cpu-s/118490/?page=0&pageSize=10 guide for global data communication Hope this helps you
4/24/2015 10:25 AM | |
Posts: 93 Rating:
Hi balakrishnan, we are using GLOBAL DATA COMMUNICATION for data exchange between two S7-400 CPU i try to increase the lenth of the data exchange,i m edit the GD TABLE select the sent/receive option.i dont know how to edit or create the GD ID. can you guide me how to create the GD ID. Here i attached my netpro backup and my GD TABLE. pls guide me. i m waiting for your reply. Thanks & Regards, Suryamuni. AttachmentGD DATA increase_byte_length.pptx (397 Downloads) |
4/24/2015 11:36 AM | |
here is the configuration manual..... Attachmentcp_e12_0_2_e.pdf (482 Downloads) |
5/4/2015 10:47 AM | |
Posts: 93 Rating:
Hi bala, i go through that configuration manual,now i edit the GD TABLE and after compile the GD ID automatically created.now my project GD function data transfer between two plc working good.here i attached my edited GD TABLE., My issue is solved.Once again thanks to all my reply and guidance. Thanks&Regards, Suryamuni. Attachmentcomplete global data lenth increment.pptx (367 Downloads) |
2 thankful Users |
