4/14/2023 8:17 PM | |
Joined: 10/22/2020 Last visit: 9/20/2023 Posts: 130 Rating:
Hi, with respect to the IOT2050, we actually recommend NodeRED for such applications. If you say that you always have to set the configurations manually, then I advise you to take a look at the export and import options of NodeRED. This allows you to output a finished NodeRED flow as a script and scale from there. In relation to your wish to use MindConnect via the command line, this is the starting point. BR |
