11/27/2014 1:22 PM | |
Posts: 215 Rating:
Hello Suvajitb 1, maybe the following links can give some information: Compatibility Tool for Automation and Drive Technology How do you find the UL certificates for the SIMATIC modules? SIMATIC NET Network management Diagnostics and configuration with SNMP Diagnostics Manual regards |
11/27/2014 4:13 PM | |
Joined: 10/5/2006 Last visit: 3/20/2025 Posts: 74 Rating:
Hi Suvajitb1, I believe you must configure the OPC PC with SIMATIC NET V12, and separately configure your S7 PLC in STEP 7 V5.5. It means making the link between your PC and PLC not in STEP 7 V5.5, but SIMATIC NCM PC V12. SIMATIC NCM PC V12 is installed if a TIA Portal version of STEP 7 is not installed on the computer which you wish to install SIMATIC NET V12. See this link for configuration help in Simatic Net V12: http://support.automation.siemens.com/WW/view/en/77376717 Regards, Shawn |
Automation Programmer |
