10/17/2011 8:53 PM | |
Posts: 43 Rating:
As I know you don't need to cofigure anything but I recomend you at least to set the IP to the switch. Here is the Manual Industrial Ethernet Switches SCALANCE X-200 / XF-200 Operating Instructions I also recommend that you install and use the Primary Setup Tool for the setup of the swith., The PST is on the CD that came with the Switch. Regards |
