3/12/2009 10:57 PM | |
Posts: 2661 Rating: (279)
Hi sparta,
3/13/2009 1:23 AM | |
Not required. There is no Station Configuration Editor on the client. This step also is not required. In fact this might do some harm.... Try the following: 1. Shutdownpower on both OS & ES. Restart and try downloading again. 2. If it still doesn't work, look for lock files (*.LCK) and delete them. See following FAQ: How can you correct the error message "OS is currently being loaded from another ES"? |
3/13/2009 5:35 PM | |
Posts: 12 Rating: (0) |
Rebooting the ES solved the problem. Thanks for the help. It will be interesting to see if I lose connectivity again. Thanks, Pete |
