6/27/2014 10:24 AM | |
Joined: 9/2/2012 Last visit: 8/15/2024 Posts: 711 Rating: (30) |
Yes. Work memory is internal mem of cpu |
6/27/2014 2:26 PM | |
Joined: 4/22/2010 Last visit: 5/3/2024 Posts: 5697 Rating: (715) |
Hello, I think it's better to read the technical data of your CPU i.e. this one There is mentioned how much memory there is on the CPU. Regards, Marcjan |
Problem solved? |
6/28/2014 7:57 AM | |
Joined: 3/20/2014 Last visit: 12/11/2022 Posts: 87 Rating: (0) |
Dear Marcjan, Please see this... It makes clear that how we find the size of load memory and main memory in Simatic Manager... How can you determine the size of the load memory and main memory of a SIMATIC S7-300/400 CPU? Thanks Regards, RSid |
6/30/2014 2:13 PM | |
Joined: 8/19/2013 Last visit: 8/26/2024 Posts: 148 Rating: (11) |
Hello RSid, please have a look to the following page -> https://support.automation.siemens.com/WW/llisapi.dll?aktprim=0&lang=en&referer=%2fWW%2f&func=cslib.csinfo&siteid=csius&groupid=4000002&extranet=standard&viewreg=WW&nodeid0=33516848&objaction=csopen There you can find the technical data of your plc 317-2DP If you want to know the size of the memory, you can use this page to find out how big the memoryisfor every siemens plc -> https://support.automation.siemens.com/WW/llisapi.dll?func=cslib.csinfo2&siteid=csius&lang=en&aktprim=99&siteid=csius&prodLstObjId=48161943&extranet=standard&groupid=4000002&viewreg=WW&nodeid0=33516848 under "self search" I guess this is the easiest and most comfortable way... Regards ! |
