7/8/2018 12:11 AM | |
Joined: 10/17/2014 Last visit: 3/5/2025 Posts: 1 Rating:
Hello, I'm using Step7 v5.5. I'm try to connect a Trojan UV with S7-300 315-2PN/DP, but the gsdml file dont work. The file is: GSDML-V2.0-XPort-PNIO-MB-20130701.xml The problem is in the check box for select "Assign IP address by controlling IO", this check box is ON and disable for change. Its possible modify a GSDML file for enable this check box and disable this option? Thank You. ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 7/9/2018 8:07:01 AMNew subject after splitting |
