2/21/2017 4:54 AM | |
Posts: 3 Rating:
I have 18 HMI , i want connect to a PLC S7_1200 (cpu 1215) via Ethernet IP . can i connect to? |
2/21/2017 6:28 AM | |
Joined: 5/12/2006 Last visit: 3/20/2025 Posts: 22572 Rating:
Hello, the max connections you can find in the technical data of the PLC. For S7 1215C here only 16 connections possible https://support.industry.siemens.com/cs/ww/en/pv/6ES7215-1AG40-0XB0/td Regards |
2/21/2017 1:05 PM | |
Joined: 8/3/2009 Last visit: 3/20/2025 Posts: 15045 Rating:
Hello look at this FAQ this are the information you need: https://support.industry.siemens.com/cs/ww/en/view/109479986 Bye Murof |
