11/19/2018 11:20 PM | |
Joined: 6/25/2018 Last visit: 1/15/2025 Posts: 60 Rating:
is your network in the same ip-range? |
11/20/2018 6:59 AM | |
Joined: 5/6/2010 Last visit: 3/13/2025 Posts: 2012 Rating:
Hello, you want to connect your PLC over WLAN, is this correct? You need a few ports which are must open for the communication. The easiest way is you connect your PLC over a switch. regards |
11/21/2018 10:06 PM | |
have you set the ip address of your ethernet connection(on computer) to 192.162.2.xxx? |
