12/11/2011 12:32 PM | |
Posts: 27 Rating:
Hi all, I have fourquastions in my Issue. Iwant to programm the following HMI screen: KTP 600 basic color DP (6AV6 647-0AC11-3AX0) with winCC flexible 2008 [schnippschnapp] - KTP 600basic color(6AV6 647-0AC11-3AX0) ?? -What aboutTP 177 PN/DP (6AV6 642-0BA01-1AX1) ?? Third: I want to connect one of the HMI devices (above) to a PLCS7-200 station(controller CPU 224). Which one of the HMI devicesis compatiblewith the CPU 224controller? because KTP600 have RS 485 interface and I'm not sure if the CPU 224 can communicate with it. [schnippschnapp] other questions can be found in the following threads KTP 600 basic color DP and WinCC flexible 2008. transfer my program to KTP 600 basic color. Communication between Panel and S7-200 Thank you very much for taking time Best degards |
Last edited by: O_Moderator at: 12/13/2011 8:22 AMLast edited by: O_Moderator at: 12/13/2011 8:22 AM |
12/11/2011 3:26 PM | |
Joined: 3/21/2006 Last visit: 2/10/2025 Posts: 10239 Rating:
[schnippschnapp]
Both panels are "compatible" with S7-200. Take a look at Which HMI components can you connect with S7-200 CPU and what should you watch out for when doing so? [schnippschnapp] Best regards, Hristo Mihalev |
