7/2/2018 9:49 PM | |
Joined: 9/27/2006 Last visit: 3/28/2023 Posts: 11998 Rating:
Hello Jim; Do you have a Profibus master module for the CompactLogix platform in your rack? The PP-17 II acts as a Profibus-DP slave (though it can be adapted to MPI to work with a S7-200). Look at the offerings from Prosoft, for example:
https://support.industry.siemens.com/cs/us/en/view/1142916 Hope this helps, |
7/3/2018 2:52 PM | |
Posts: 23 Rating:
Daniel, I appreciate the reply, but have a few more questions. From the manual, it looks like it might work if set up for Profibus-DP, but a reply from Tech Support says there are no drivers for AB/Ethernet. I'm guessing the drivers would need to be in the COM-PROFIBUS or HW-PROFIBUS software, so this panel will only work with STEP 5 or STEP 7 software? Thank you. Jim AttachmentSiemens Tech Support.docx (21 Downloads) |
