10/27/2020 12:38 PM | |
Joined: 2/5/2016 Last visit: 12/4/2024 Posts: 4 Rating: (0) |
I have the same problem - after trying to connect Siemens field PG M6 to S5-100U CPU 103 no connection can be establish, in STEP5 v7.23 the message come out "PLC in cycle - stack output stopped". I have been switching between all available com ports in STEP5. Also I have an old PG720P with STEP5 v7.02 - it connects easily with its old cable and new cable from PG M6 as well. As for the article "Error message: "PLC in cycle, stack output aborted" when setting up an online connection from a Field PG to an AG100U" that fritz advised - there is no Logitech folder in my PG M6 registry. The problem must be on PG side. Please suggest a possible solution. ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 10/28/2020 05:53:31New subject after splitting |
