4/24/2007 1:31 PM | |
Joined: 2/23/2007 Last visit: 2/19/2023 Posts: 75 Rating: (1) |
Hi all, I need configure TD17-DP12 with IM308-C and S5115U-943B. I looked for GSD file to this TD but only found TD17 without DP or DP12 on library. I contact support then they had ordered i search GSD file on: https://support.automation.siemens.com/WW/llisapi.dll?func=cslib.csinfo&lang=de&objid=113264&caller=view I look, but also not found TD17-DP12, only OP7-17_DP12 and TD17... My question is wich correct GSD file i use for this HMI??? I not have hardware here for test!! In atached file show the COM PROFIBUS and COM ET200, in COMET200 i try connect same hardware but also not found GSD(*.200) file . Thanks for any help. Oliveira, M AttachmentSiemens_Support.zip (668 Downloads) |
4/24/2007 11:26 PM | |
Thanks!! I bealive now i understood!! I go use OP7/17-DP12 GSD file! corect? Thanks! |
