8/27/2006 5:38 PM | |
Joined: 1/7/2006 Last visit: 12/23/2024 Posts: 2705 Rating: (320)
Hi Felix, Is that the Display or the keyboard? [:P] Normally nowaydays you don't have a GSD-file for the Siemens-panels! [;)] I didn't find the ABB systems in the handbooks for the communication between the display(s) and the ABB PLC. [:(] Please read the 2nd manual carefully to check if you may use a ABB with this software WinCC Flexible. [:o] WinCC flexible Communication Part 1 WinCC flexible Communication Part 2 |
9/1/2006 11:05 PM | |
Posts: 5 Rating: (0) |
Hello How I can find a GSD file for a Dsiplay Simatic OP77B? Is't exist? Thanks |
9/8/2006 4:24 AM | |
Joined: 5/19/2006 Last visit: 12/3/2024 Posts: 549 Rating: (107) |
Hi felix, Withthe older version (Protool) it used to be an Open Platform Program SDK that helped to extend MPs functionality. I don't know if WinCC Flex follow the same path, perhaps you can search around for this. I will give a call to Software Toolbox to see where their are as far as new Siemens panels (www.softwaretoolbox.com) Take a look also on www.paneldrivers.com/siemens/index.html Dec |
Last edited by: Dec at: 9/8/2006 4:37 AMLast edited by: Dec at: 9/8/2006 4:31 AM |
9/8/2006 5:00 AM | |
You can use S7-200 & EM277 as a proxy gateway in between the panel and ABB Profibus Master Dec |
