10/23/2006 12:08 PM | |
Joined: 8/31/2005 Last visit: 5/17/2023 Posts: 217 Rating:
Hi! You could do it the same way by writing an ActiveX control, that accesses the serial port of your PC. I'm not a WinCC expert, so I don't know if there is a way to do that directly in WinCC. You should ask this question in the SIMATIC HMI Human Machine Interface conference. |
Greetings, Chris |
11/7/2006 12:49 PM | |
Hi! I know, that there are some ActiveX components, that don't work with WinCC (but I don't know why - try to ask this in the SIMATIC HMI Human Machine Interface conference). If you are looking for ActiveX controls for serial connectsions you should try Google: http://www.google.de/search?q=activex+serial+connection I also found this article: Serial Communications with ActiveX at www.codeguru.com. |
Greetings, Chris |
