6/30/2018 12:13 AM | |
Joined: 9/27/2006 Last visit: 2/11/2025 Posts: 12334 Rating:
Hello Fructuoso`; What Ethernet module do you plan on using with your OMRON CPU? The CJ1W-PNT21 module is developped for Profinet communications, and would make it very easy to use with your G120 drive.(the CU250S-2PN is a Profinet-enabled controller). If you decide to go with the Profinet interface, here is an series of application examples, one of whuich is for a G120 over Profinet, with a S7-300 CPU. you can use that as a structuring example for your own project. https://support.industry.siemens.com/cs/ww/en/view/60441457 Hope this helps, Daniel Chartier |
6/30/2018 3:34 PM | |
Posts: 5 Rating:
Hello dchartier! I know could be easier withy profinet, but we have a complete sysytem built with ethernet. And I had to replace a VFD damaged with the Siemenes one and now i have some troubles with the integration of this. I've tried all the steps included in "Getting Started connecting SINAMICS G120 Drives to EtherNet/IP™" but still I can't get communication with the VFD. Thank you so much for your kindly Help. |
6/30/2018 4:13 PM | |
Posts: 5 Rating:
Sorry I'm using the OMRON CJ1W-ETN21 for the ETHERNET communication. |
