11/10/2007 12:24 PM | |
Posts: 1 Rating:
Hi, Does someone knows what is the best way to do this type of connection?? please see the attachment below |
11/12/2007 5:04 AM | |
Joined: 9/27/2006 Last visit: 3/23/2025 Posts: 12344 Rating:
Hello Marcin65; Siemens proposes a solution, a Matlab/Simulink DDE client connection to S7 (Simatic Net or WinCC). Ihave collegues who have used it in a complex control application, based on PCS7. It is developped by the IT4Industry division of Siemens; you will find PDF and PPT presentations for it at the bottom of the following page: http://www.industry.siemens.com/IT4Industry/en/solution_services/simatic_addons/fuzzy_download.htm?PIdent=1001&SIdent=1018&TIdent=1031&QIdent=1042 This might not be exactly what you are looking for, Siemens Add-On products are generally expensive (small market...). But they are stable, tested and supported. Hope this helps, Daniel Chartier |
7/19/2013 8:39 AM | |
Joined: 4/24/2009 Last visit: 8/20/2024 Posts: 2682 Rating:
Follow-up-question splitted to connection Matlab with PLC S7-300 Best regards O_Moderator |
