7/6/2013 9:30 AM | |
Posts: 55 Rating:
hello sir i saw you know very well all this system and you have all time the good answers,with example please help me for arrive and finish my projects,i lost already 2 weeks and still i can see the finish i am in italy,and i called on milano,but the gays,is ,,too busy,,so,i have two solutions,or i finish with siemens or i can find one person wich is capable to do technical assistance i saw and i received one call phone for instructions for connection modbus,and still have the error,not work,all examples from manual,or i finded i this forum is different+incomplet,and i dont know for what reason ,still not work i use tia v12 trial i atached one small programm,naybe you have some time for see thank you in advance
Attachmentcapture_007_06072013_093013.zip (58 Downloads) |
Last edited by: O_Moderator at: 7/8/2013 12:54 PMnew subject after splitting from /tf/WW/en/Posts/94252#top |
7/8/2013 2:42 PM | |
Joined: 11/8/2011 Last visit: 3/7/2025 Posts: 387 Rating:
Hi AutoGen_667937 Can you proive in detail Which module are you using |
7/8/2013 3:17 PM | |
Posts: 559 Rating:
Dear AutoGen_667937, Which printer you are using? If you printer support Ethernet TCP communication then I suggest you to go for Ethernet only. So in this case you can directly use inbuilt Ethernet port of PLC. |
