6/11/2012 9:33 AM | |
Joined: 10/20/2009 Last visit: 6/24/2019 Posts: 10 Rating:
I'm trying to establish connection between an MP277 OPC XML Server and an OPC DA Client installed on WinXP Professional PC. To achieve the goal I'm using the OPC XML Gateway as it's explained in https://support.automation.siemens.com/WW/llisapi.dll?query=25677751&func=cslib.cssearch&content=adsearch%2Fadsearch.aspx&lang=it&siteid=cseus&objaction=cssearch&searchinprim=&nodeid99= Unfortunately, I obtained different results. First, I tried on my PC where I've also installed developement software (wincc flexible, step 7, etc. etc.) and I got the data from OPC Server. Second, I tried on a computer where I've installed only OPC XML Gateway and some OPC Client DA, but in this cases I wasn't unable to read data even to browse OPC Item. I've tried also to specify directly item path without browsing OPC but I can't got any good value. |
12/18/2015 8:30 AM | |
Joined: 4/10/2015 Last visit: 10/6/2022 Posts: 2 Rating:
Hello, Did You solve problem with this connection?
