2/25/2018 3:29 AM | |
Posts: 137 Rating:
Hi, I want to connect Notebook to S7 1500 on VPN How? Thanks |
2/25/2018 6:00 PM | |
Joined: 3/28/2015 Last visit: 2/15/2025 Posts: 722 Rating:
Hello, Kindly have a look at the attached file. 1-Turn off firewall on both PC'S 2-Turn off antivirus on both PC'S 3-Follow the procedure as in the attached file. 4-On the remote PC, enable IP router. 5-On the local PG, add a route to the PLC. 6-Accessible nodes in TIA Portal not possible with VPN 7-Connect directly through IP address. AttachmentHow to setup Teamviewer VPN.pdf (256 Downloads) |
Eng.Mohamed Ibrahim |
2/26/2018 6:42 AM | |
Joined: 5/12/2006 Last visit: 3/25/2025 Posts: 22600 Rating:
Hi, have you already assign a IP to the Scalance X208? Regards Christoph |
2/26/2018 7:15 AM | |
Posts: 137 Rating:
Hi, Yes , it is 192.168.0.1 Thanks |
2/26/2018 7:26 AM | |
and the other things? |
2/26/2018 9:24 AM | |
Posts: 137 Rating:
Hi, X208 192.168.0.1 S7 1500 192.168.0.2 PG 192.168.0.200 Thanks |
2/26/2018 9:27 AM | |
why you don't answer the other questions? |
