9/12/2011 5:05 PM | |
Posts: 41 Rating: (1) |
Hi, E-Tele, i am also having the same application,(i.e i want to control 3-element system using pid block). i know how to use a pid wizard for 1 pv.but i dont know for 3 pv to use in a pid block can u guide me.... if possible send sample program.. thanks krk Splitted from Designe 3-Element PID Loop in S7-200. |
9/13/2011 9:25 AM | |
Posts: 17 Rating: (0) |
Dear Suvarn, i have done it with Delta PLC not with Siemens, if you wish i can send you the program designed in Delta you just convert it into Siemens..... |
9/13/2011 9:33 AM | |
Joined: 4/24/2009 Last visit: 2/19/2024 Posts: 2683 Rating: (135) |
Thread closed, because question is already published in the following thread 3 element control using pid. Best regards O_Moderator |
