11/22/2012 10:13 AM | |
Posts: 1547 Rating:
Hello, the easiest way would be adding an Ethernet CP to S7 300 Station. From S7 300 you can access all PROFIBUS stations by Step 7 routing function. The cheapest CP is CP343-1 LEAN --> 6GK7343-1CX10-0XE0 On your PC everything is delivered with Step7. Youcan use your onboard Ethernet or Wi-Fi card for this. |
